R1 rear shock
mick the brush
hey all . is there a certain year of the yam r1 that the rear shock will fit to a lambretta, or will all fit?? its a toss up between the new bgm or a r1??
the smell of solvents, t'is what makes me happy!!!
any year as long as the cylinder is upright
deanlam185
personally i would go for the bgm its designed for a lambretta the R1 shock is for ? an R1 unless its going to be striped re valve re sprung etc, ££ you might aswell go for the bgm looks nicer aswell.
Knowledge
The R1 shock does not fit SI or SII frames very well and you must take care when securing the nuts at the top and bottom. Too tight, and the shock might break.
Martin
DJB
Knowledge wrote:The R1 shock does not fit SI or SII frames very well and you must take care when securing the nuts at the top and bottom. Too tight, and the shock might break.
Use the double nut method
teamsequipe
whilst the nuts need to be tight obviosly,they should not tighten up against the shocker bushes and so restrict the slight amount of movement that they require under suspension movement....
DJB
sean brady scooters wrote:whilst the nuts need to be tight obviosly,they should not tighten up against the shocker bushes and so restrict the slight amount of movement that they require under suspension movement....
And by using two thin nuts, locking them together , this can be achieved.
chiggy03
Why not use nyloc half nuts?
DJB
chiggy03 wrote:Why not use nyloc half nuts?
I would rather use 2 nuts for peace of mind, ;)
