Page 1 of 2
Could it be the reeds
Posted: Sat Feb 27, 2021 9:07 pm
by boxofbits
Just popped to the shops on my GT 186 came to a hill so gave it some then all power went pulled clutch in the bumped in 3rd then took it slow home then I tried to give it a bit more and did the same again thought it may be faulty stator but readings are fine with a volt meter and I tried new CDI plug etc and did the same. Now when I start it it will not rev and just stales if any load is given. Was getting dark do chucked in the shed. Would knacked reeds give this effect?
Re: Could it be the reeds
Posted: Sat Feb 27, 2021 9:47 pm
by Norrie Bodge
LT coil
Posted: Sat Feb 27, 2021 10:30 pm
by boxofbits
Cheers never thought the LT coil woundnt readings on volt meter be low if that was the fault?
Posted: Sat Feb 27, 2021 10:33 pm
by Norrie Bodge
boxofbits wrote: ↑Sat Feb 27, 2021 10:30 pm
Iv had good readings from a few stators with failing low tension coils m8
Posted: Sat Feb 27, 2021 10:49 pm
by boxofbits
Cheers will change it tommrow may as well do reeds while I'm at it been in a while
Posted: Sat Feb 27, 2021 10:53 pm
by MightyGem
Just out of curiosity, what are "reeds"?
Posted: Sat Feb 27, 2021 11:06 pm
by boxofbits
It's got a Reed valve which has fibre petals reeds these can split or even break meaning engine runs rubbish
Posted: Sun Feb 28, 2021 10:00 am
by Tractorman
Just got one in that would not run at all, one petal was completely missing.
Posted: Sun Feb 28, 2021 10:21 pm
by MightyGem
boxofbits wrote: ↑Sat Feb 27, 2021 11:06 pm
Thanks., and these are fitted where?
Posted: Mon Mar 01, 2021 11:18 am
by Toddy
MightyGem wrote: ↑Sun Feb 28, 2021 10:21 pm
Under the inlet manifold Into the inlet of the cylinder widened to fit a Reed block in
