Hi, my brake light only seems to come on when my lever is fully pulled in and when my pedal is fully pressed down.
Any ideas on how to correct this please?
Thanks.
Brake Light Only On When Brakes Fully On
- registered user
- Contact:
I would just check the general condition and contact cleanliness of the switches.
The one on the front brake is worked by the MC plunger and switch on the underside of headset, strip the switch and clean it.
The back brake means stripping the pedal out. It may require a new switch. Slacken the back brake cable off, undo the 3 bolts off the pedal then drop it from the frame. The switch is a blue or grey plastic box bolted to the pedal. Strip it out and check condition then clean.
- pooliepfr
- registered user
- Main scooter: Vespa PX 125
- Contact:
Great, thanks Gaz. I think i should be able to manage those two tasks.gaz_powell wrote: ↑Sun Mar 01, 2020 8:54 am I would just check the general condition and contact cleanliness of the switches.
- registered user
- Main scooter: Lambretta L.I. 200 special
- Contact:
WD40 works wonders on brake light switches
