Quattrini M1XL
Fabbian von minky
Main scooter: vespa
Hello
Building a M1XL from scratch have couple questions.
Casings to weld or not to weld have matched casings but have left myself couple MM leeway to gascet so not gone to mental with the dremel, anyone running this kit without welding the casing(will be running full circle crank).
Second question purchased a pinasco 1400grm flywheel to run with it have Zeus CDi and need to get a stator for it , any recomends make wise or should I go for a kit Parma Vespatronic ? Has anyone a before after experience with the Vespatronic type kits much gain etc worth the money ??
Boreham
Main scooter: GP225
I had a similar dilema on the flywheel and made a few expensive mistakes, basically the larger transfers on the barrell effectively 'bulge' out which means many of the traditional flywheels (inc HP4) do not fit, they foul the transfer when fitted.
The Vespatronic does clear with room to spare, i suspect the Pinasco flywheel will be fine as all based on the same Miranelli system
Suggest dry building to ensure the clearance, re the stator again all based on the same components, as for performance, it does help with the extra advance at lower revs.
The one downside with all these kits is the p155 poor output! Do not expect any lights or horn at tickover, the claimed output of 90 watts is somewhat optimistic!
I've got a Malossi one. Lights work at tickover really well.
It's a bit too light with the (easily smashed) plastic flywheel on it. Way better with an aluminium one.
Ginch
Main scooter: Vespa 150 Super
Muttley McLadd wrote: Mon Aug 07, 2017 9:52 pm I've got a Malossi one. Lights work at tickover really well.
Do they make weights for the Malossi?
I believe they do. But, with one of these on:
Mine goes alright.
Ginch
Nice!
