float pivot pin stuck
- registered user
- Main scooter: Lambretta li150 special
- Contact:
Try warming the pillars with hot water and use vise grips instead of pliers.
- registered user
- Main scooter: Lambretta GP
- Contact:
I can't remember whether the pin hole / drilling goes all the way through on an SH or Jetex, however, on one or t'other I have managed to start it moving by poking the other end, then got it loose enough to remove from the correct end.
Good luck with it.
Adam
Good luck with it.
Adam
- Suede Ed
- registered user
- Main scooter: SIL GP200
- Contact:
Cheers chaps, got it out using needle nose mole grips, following the carb being left in my new (off ebay) ultrasonic cleaner, ill put a post up on this later, including pictures.
