Scooter Carb Set-ups
Hello Everyone,
I'd like some help from the forum members if possible, i have two requests:
1) If you have any carb/jetting related questions, please can you post them in the carb section (Here: http://scooterotica.org/forum/viewforum.php?f=9) and not in Lambretta/Vespa Tech? Cheers
2) This is the more important of the two, we want our listings of known carb settings to grow, and become a reference point for people to use, so if you have any known jetting settings, please can you check if they are already on the Vespa/Lambretta 'Carb set-up' lists (links below), and if not......please add them! Then everyone can benefit from the knowledge.... 8-)
Dan
Vespa Carb Settings: http://scooterotica.org/forum/viewtopic.php?f=9&t=15
Lambretta Carb Settings: http://scooterotica.org/forum/viewtopic.php?f=9&t=14
