T5 or P2
- registered user
- Main scooter: Lambretta
- Contact:
Thanks for the thoughts you've pretty much confirmed my thinking that the P2 motor was the best basis to work from.
- registered user
- Main scooter: T5 172 Tv 240
- Contact:
A malossi 172 T5 engine is fast, very easy to build and, depending on which exhaust and clutch gear is fitted, can be torque fest or rev monster! An iron barrel polini p2 takes alot of time, knowledge and patience to get right. Not an easy build.
- bazman
- registered user
- Playstation gamer tag: bazman70
- Contact:
Hence why I mentioned the Ali polini kit , pisses all over t5's with or without a kit on in my experience. And bags of tourque, what the piaggio group should have built instead of those pug ugly gts's
- registered user
- Contact:
Just had the pig out with scuds T5 engine in for a shakedown, had to wring the neck off it to get it over 60 on the clock.
Our mutual friend is locating a suitable set of p2 metal in the garage as we speak.
- registered user
- Contact:
LOLcorrado wrote:What's a P2? Sorry I'm a mid life Lambretta buyer, new to the scene.
- registered user
- Main scooter: Li Avanti 225
- Contact:
It's what we normally see driving 2 up, loaded with gear, driving relatively slowly, when we're stuck in the lay-by making "adjustments" to our faster Lambrettas......corrado wrote:What's a P2? Sorry I'm a mid life Lambretta buyer, new to the scene.
- registered user
- Contact:
I've no experience of the alloy polini kit but I'm very curious. Has it the same ports and piston as the iron barrel or have they improved it?bazman wrote:Hence why I mentioned the Ali polini kit , pisses all over t5's with or without a kit on in my experience. And bags of tourque, what the piaggio group should have built instead of those pug ugly gts's
- corrado
- Dealer
- Main scooter: Lambretta GP
- Contact:
Ah, the ones with the indicators always on. Or the ones who asked me to join them on the motorway "No" says I "I'm only tooling along at 55 with the trucks" ... " Oh OK, we're doing 65" ...... then 10 minutes later I proceeded to pass them at 55.mick1 wrote:It's what we normally see driving 2 up, loaded with gear, driving relatively slowly, when we're stuck in the lay-by making "adjustments" to our faster Lambrettas......corrado wrote:What's a P2? Sorry I'm a mid life Lambretta buyer, new to the scene.
- registered user
- Contact:
yes it's the second lot with the 70mph + speedo's that can "probably" beat a TS1, but develop "fuel starvation" or hear pinking when over 60.........corrado wrote:Ah, the ones with the indicators always on. Or the ones who asked me to join them on the motorway "No" says I "I'm only tooling along at 55 with the trucks" ... " Oh OK, we're doing 65" ...... then 10 minutes later I proceeded to pass them at 55.mick1 wrote:It's what we normally see driving 2 up, loaded with gear, driving relatively slowly, when we're stuck in the lay-by making "adjustments" to our faster Lambrettas......corrado wrote:What's a P2? Sorry I'm a mid life Lambretta buyer, new to the scene.
