Guys, trying to remove a mate's engine and the bolts seized quite solid. I can't knock it out either way and worried if i hit it too hard that the engine lugs will break, any ideas to remove engine bolt appreciated ?
Thanks
Engine Bolt Removal
- Main scooter: Lambretta LI Special 225
Lambretta?
I hope so,Yanker wrote:Lambretta?
If he hits a Vespa one both ways, one will cause trouble
- Main scooter: Lambretta Series 2 Li 150
If Lambretta, it's likely to be seized in the engine mounts, so take off both nuts, spray thoroughly with plusgas or similar and leave overnight. Then put some large washers the same internal size as the original washer on one side only as packers, refit the nut and tighten to draw the bolt out. Keep swapping sides until it frees up. Oh, and take it easy, and if it doesn't work, ask advice on a different method, but this one worked for me!
Sure would if you did not know what you were doing: applies to both marques!?lambro wrote:I hope so,Yanker wrote:Lambretta?
Thanks, i'll try that method, yes its a lambretta......whoever built it never put copper grease on the bolt.....DOH !!
Thanks....it worked, but blimey proper tight in there ....cheers again !
Incidentally we tried a mate's new engine bolt on the engine and it went straight through with no resistance, maybe we'll have to give it a gentle grind down.....
