Avanti ex box
Hotdog
I’m currently running the ST version but thinking of changing this for the standard one, but is there much difference in noise between the two as wanting a more quieter exhaust and i think the performance between the two are marginal. Thanks
The ST is straight through no baffle hence the end can don’t know about performance but they are only a little quieter
Hotdog
Ok thanks as long they are a bit quieter I might have to get one as there not much out there if you want a clubman without the end can and a decent sized tail pipe.
Hotdog wrote: Wed Apr 03, 2024 3:46 pm Ok thanks as long they are a bit quieter I might have to get one as there not much out there if you want a clubman without the end can and a decent sized tail pipe.
Have you looked at the SIP clubman ?
Hotdog
I haven’t but ain’t they more or less like a Bgm exhaust ?
Hotdog wrote: Fri Apr 05, 2024 6:05 pm I haven’t but ain’t they more or less like a Bgm exhaust ?
Yes but based on the earlier version which was better than the later ones
    Users browsing this forum: Majestic-12 [Bot] and 8 guests
