LML indicator problem
parky
I have in the past often had indicator problems with the above 125 star but have always managed to overcome them. However this time I am struggling to sort this one out. The problem being that my left side indicator has totally packed up but when I throw the switch the headlight on the scoot flashes as if it were the indicator. I realise something is probably shorting somewhere which is likely causing this to happen but at the moment I am baffled. Any ideas please as I need to get the scoot MOT'd but need this sorting first.
Thanks
Daggs
I have no particular knowledge of the LML Star. But the fault you describe is commonly due to bad earth/body connections.
    Users browsing this forum: Ahrefs [Bot] and 2 guests
