Hi all,
I’ve just purchased a quality made ,rear hub nut.But when I went to tighten it up .There’s no thread left.At least 3mm.Yes I used the normal washer.And yes I am using torque wrench
Rear hub nut
- registered user
- Main scooter: Lambretta 125 special
- Contact:
Try comparing it to the old nut if you have one available.
- registered user
- Contact:
Hi,
The old nut is a pike nut, with unlimited thread. I just don’t understand. I bought it from a quality dealer.Where everything is British made
- registered user
- Main scooter: Lambretta SX200
- Contact:
I'm not sure why you don't understand that some dealers will sell inferior goods, to the point of them being dangerous, whilst making claims to the quality.Simon lambretta wrote: ↑Tue Jun 08, 2021 1:00 pm Hi,
You need to make the dealer aware & receive a full refund.
Recently, I read great claims about their own products from a dealer, reiterating that their sprocket drive bolt was the strongest available. Great.......If that bolt is too long, it bottoms out, preventing correct torquing & allowing the Cush drive cams to ride over one another.
BTW. The thread size is M16 x 1.5 & is common to the engine & suspension mounts. A couple of spare nuts can always be used to pull up the hub & even as a 'get-you-home' measure. Two nuts locked together is quite safe IMO.
- registered user
- Main scooter: Lambretta Li125
- Contact:
That doesn't mean its good quality, its usually quite the opposite.Simon lambretta wrote: ↑Tue Jun 08, 2021 1:00 pm Hi,
- registered user
- Contact:
Hi all,
Phoned up the dealer today.It turns out they are faulty. Makes me reallly angry. They must have known it was faulty. I won’t be using the most expensive dealer ever again.
