VESPA GTS 2012 COOLANT QUESTION
I have purchased some Castrol motorcycle coolant in order to replace the existing coolant in the scoot. However I have just noticed it says on the bottle do not use in Magnesium Alloy engines. Does my GTS have such an engine? or is the coolant which complies with ASTM D3306(I) ok to use. Thanks for any advice as I am a bit confused......
