On eBay I see clutches listed with 20, 21, 22, and 23 teeth. Far less offers of 20 tooth clutches.
Have seen comments here and there about trading acceleration for top speed or vice versa by using a clutch gear with a different number of teeth.
What is the standard or factory default number of teeth for the clutch gear in the P200e?
How much can the gear be changed without also having to change the tree cluster?
Thanks
Clutches for P200e
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
23tooth clutch on the P200E or PX200E
using a P125(early) or T5 fourth (for later PXE) shortens the gearing slightly so will pull 4th better but you’ll loose a bit on topend
- Muttley McLadd
How much would you want to change it? I'm fairly sure DRT make all sorts of different gearing options.railfancwb wrote: ↑Tue Aug 06, 2019 5:12 am
What is it you want to achieve?
- Main scooter: vespa t5
P200 is 23/65 standard, have a look on scooterhelp at their gearing calculator for a guide. I'm currently looking for a 65t cog for my spare engine and struggling to find one second hand.
My preference for a tuned engine is 23/65 on a 125 box, but never tried the 67t cog in any combination so who knows what that's like
