Hubs matt laquer or gloss finish
mr mugello
Lambretta hubs mettalic grey hubs are in for paint. Gave the lecler codes for hubs but was asked what laquer finish I wanted. Gloss or matt ?
mr mugello
What would be nearest to original match to a series 3 SX ,GP Italian paint.
Which would you like the look of most? It's your bike.
mr mugello
Original finish . I believe the sprayer is using two pack paint, not celluose and is not familiar with restoration work of Lambrettas. I guess matt laquer myself would be nearest, but I just thought I'd ask the question.
I'm a bit confused by his offer to laquer it for you. If it's done in a nice 2Pac paint it won't need laquering. I suspect he's referring to the finish of the paint, and not necessarily talking about a second layer of varnish.
mr mugello
Probably right. He just mentioned matt or gloss. I just presumed clear laquer is applied over top of a colour. He just pointed over to an alloy car hub in grey. He didn't mention about the white finish I wanted for the internal parts, cowlings , tank , etc. I'm thinking just gloss finish for everthting on scoot now.
It will be. That's what 2Pac is basically.
mr mugello
Doom Patrol wrote:It will be. That's what 2Pac is basically.
Forgive me Doom Patrol, but do you mean 2pac is basically "gloss finish".
Well, as far as I know it is. As I understand it it's designed specifically so that you don't need a laquer top coat. I'm not saying you can't get a matt finish. Typically, I'll probably find you can now. :D
mr mugello
Just looking into all the diffrent paint make up cellulose, water based 2pac, acrilyc 2pac. I'm not sure what spec of paint he is going to use. I have read that the the latest eco friendly water based 2pac scratches easily. Will have to check with sparyer.
