Page 1 of 3
AF Kit Pistion Rings gone again
Posted: Sat Jul 23, 2016 6:37 pm
by Lamaddict
Great little kit but I've just popped the second piston due to the rings breaking up and pinking out through the exhaust. What causes them to break up? I might get another kit or get another rebore.
Running through a 20mm Dellorto and SIL Clubman. Carb main jet was slightly weak but the plug was still brownish.
I use semi synthetic at about 25/33 -1.
On points.
Re: AF Kit Pistion Rings gone again
Posted: Sun Jul 24, 2016 2:38 am
by scooterslag
Ports too large causing the rings to snag and break?
Posted: Sun Jul 24, 2016 9:16 am
by Scooterdude
Exhaust port to wide. Ditch it and get another you'll never stop it happening otherwise.
Posted: Sun Jul 24, 2016 2:56 pm
by Adam_Winstone
A pal repeatedly broke rings because of his exhaust port being too wide. He did something like 6 pistons before finally admitting defeat and getting a different barrel.
Posted: Sun Jul 24, 2016 4:46 pm
by Scooterdude
Who ported it? Go back to them and get them to stand the cost of a new barrel.
Posted: Sun Jul 24, 2016 5:03 pm
by Lamaddict
So I've stripped it down. As I thought, half the bottom ring went out through the exhaust port. You can see where the ring caught the top of the part of the exhaust port. It's a standard AF 175 kit. I'll take it in and see what they say. Maybe a thicker base gasket might work but I'll probably get another kit, more damn money.
Posted: Sun Jul 24, 2016 5:12 pm
by handofdave
ring gap on assembly
Posted: Sun Jul 24, 2016 6:41 pm
by Lamaddict
He checked the ring gap in front of me last time. It's a shame as the kits can go well.
Posted: Sun Jul 24, 2016 9:13 pm
by Lamaddict
Posted: Sun Jul 24, 2016 10:01 pm
by holty
it not that easy to see from the pic, port doesnt appear overlarge, maybe some more pics, is the edge of the port chamfered ?
