Some thoughts please Gents.
I'm trying to help out a friend of a friend who has recently bought a Lambretta from Vietnam.........
There were initial problems with it starting due to a crap choke cable and a 22mm Jetex sleeved onto a standard
"150" inlet manifold. All now sorted due to the application of a new choke cabke, a remade Scootopia 22mm carb and the correct inlet.
Bike starts 3rd kick and runs sweetly.
The owner is not "Lambretta knowledgable" ( we all have to start somewhere), and now advises me that when hot and approaching junctions and lights etc, the engine races on when putting the bike into neutral.
He switches off and rekicks the bike and all is well until the next set of lights etc.
I have not had a look at the machine yet, and my thoughts purely on his description are:-
1) throttle cable/ carb sticking somewhere?
2) air leak??
I am inclined to think the throttle is sticking somewhere rather than an air leak due to the fact that the bike runs sweetly and restarts OK.
Anyone got any thoughts?
I just don't fancy removing the stator housing etc.
Chris
scooter revs when stood at lights.
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
Scootering since 1968.
- registered user
- Main scooter: Li Avanti 225
- Contact:
Agree with either air leak or something sticking.
He needs to get his hands dirty and the next time it does it, don't touch the throttle, switch off, take the bellows off and see if the slide is too high/sticking.
With the air leak i'd be inclined to look round the carb'/manifold area first. When idling spray some brake cleaner/easy start around the suspected areas and see if the rev's change.
- registered user
- Main scooter: Lambretta Li S3
- Contact:
To quote: I'm trying to help out a friend of a friend who has recently bought a Lambretta from Vietnam.........
Stop spending anymore money now.
The above should have been your first clue, the carb issue the second clue, and the apparent air leak or other your third.
I would be extremely weary of continuing any kind of repair or even riding it.
If you know a thing or two about lambretta's then go over to his and inspect the scoot thoroughly. I would personally start with tyres, rims, brakes and associated mechanisms and bearings. If there's anything untoward thats your next warning.
As a test, consider whipping off the side casing and inspect chain, clutch etc for anything odd.
Im not suggesting that all eastern imported scooters are complete bodge jobs, but generally they are.
If ive misunderstood anything apologies, but a quick google of lambretta + vietnam will clear anything up.
scooters are great but not when they put your life in danger.
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
It wouldn't be something really simple like the throttle cable being too tight would it? Ask him if he stands up while he's at the lights.
- registered user
- Contact:
thats what I think it is- we'll see next Monday.
- registered user
- Contact:
inlet or flywheel seal Tim?
would it not be constant if it was an air leak ?
win or lose have a booze
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 2 guests
