Re: Drive side seal not air tight
Posted: Sun Nov 29, 2015 7:06 pm
How much air / pressure are you pumping in ? It should only be about 8psi , too much pressure and any seal will leak .
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
6 psicarlos fandango wrote:How much air / pressure are you pumping in ? It should only be about 8psi , too much pressure and any seal will leak .
