Page 1 of 2
Vespa Speedo refurbishment
Posted: Fri Nov 06, 2015 4:41 pm
by storkfoot
Can anyone give a personal recommendation on someone who is good at refurbishing Vespa speedos please?
I have successfully done my own Lambretta ones in the past and it's true that they appear very similar. It's getting the bevel off that puts me off having a go myself.
It's an original Rally 200 speedo. Speedo has not worked since I owned it but odometer did. The cogs on that now seem to be fusing together and turning at once.
Re: Vespa Speedo refurbishment
Posted: Fri Nov 06, 2015 4:57 pm
by cgt75b
Hi
I'm lead to believe there was a place in London that did it, but sadly long gone now.
The other one is speedoking.com.
Only trouble is its in the states, I believe he is very good though!
Good luck with it
Best regards Paddy
Posted: Fri Nov 06, 2015 5:18 pm
by storkfoot
Paddy, yes, I know about the bloke in the States. I'd have a go of butchering, sorry refurbishing, it myself before I sent it that far. "Google" indicates that Retrospective in London may do it so I have just sent them an email ( scooter dealer to reply to email Shock
Thanks
Posted: Fri Nov 06, 2015 7:11 pm
by cgt75b
If you need any bits give me a shout I may be able to help you out
Posted: Fri Nov 06, 2015 10:08 pm
by storkfoot
Thanks very much.
Paul
Posted: Mon Nov 09, 2015 9:31 pm
by storkfoot
Retrospective don't. They have recommended the lad in the States, Speedo King.
Surely there is someone in the UK?
Posted: Mon Nov 09, 2015 11:33 pm
by gaz_powell
Jem Booth works wonders with lambretta ones - cant be much difference, worth a try ?
Posted: Tue Nov 10, 2015 10:23 am
by cartmel808
Maskes Vespa offer the service on their web shop...
http://www.maskesvespaparts.com/Webwink ... meter.html ... they're based in Holland (I know your looking for 'UK') but still a lot closer than California... and cheaper aswel!
Never used them myself - but maybe worth a try...
Posted: Tue Nov 10, 2015 11:28 am
by storkfoot
Excellent. I'll follow both of those leads up. Thanks, lads.
Posted: Tue Nov 10, 2015 12:31 pm
by steve c
my friend john can get the vespa needles off but I have never managed it with out damage, I even tried a cheap chinese instrument needle puller which just broke up, they are very stiff,you might have to heat it it with a soldering iron and then pull lever it,
I will ask him, you tube needle /clock hand removal and vespa speedos some one will have it, Steve Burdette is good but the post to usa makes it costly
