series 2 side panel handle bodywork rusting through
Posted: Tue Apr 28, 2015 8:03 pm
by golf19gt
hi does anyone no if you can buy a replacement patch for a series 2 mine have rusted through where the panel handle fits through any advice
Re: series 2 side panel handle bodywork rusting through
Posted: Mon May 11, 2015 8:06 am
by gavi4t
do you mean the hole on the panel itself? if so get your old panel and put socket in the raised section inside (youll have to drill off the inner bracket first ) as a size guide ,get a nother piece of metal you are going to use as a patch and give the soket a good tap over a bigger socket on the other side this will give you the raised section you need ,drill a hole through the same size as your handle bolt and then weld in your patch after cutting it to size simples ,hope you make sense of this and it helps cheers gav
Posted: Sun May 31, 2015 10:52 am
by Daggs
Great idea gavi4t, consider it nicked...............
