Air box removal seizes
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
The bolt should have a square head so it doesn't spin.If someone has replaced it with an ordinary bolt you can get a flat bladed screwdriver in from the other side (battery side) and lock the screw head so it doesn't spin.
- registered user
- Main scooter: Lambretta li150 special
- Contact:
Never had this problem but if you get a length of wire, coat hanger size or maybe a little thicker, hammer one end into a wedge shape the bend it near that end 90 degrees you should be able to put that end in beside the square head and stop it turning. Just an idea I hope works for you.
- registered user
- Main scooter: Li125 series 3
- Contact:
Thanks very much I'll try both. I think it probably still is the square bolt but has rounded enough for it to spin. I tried getting a screwdriver in from the bottom of the bracket but to no avail. Thanks again
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
What I've done in the past is wedge an alan key in there. Stops the nut turning.
- registered user
- Contact:
That sounds better than my idea!Doom Patrol wrote:What I've done in the past is wedge an alan key in there. Stops the nut turning.
- HxPaul
- registered user
- Contact:
You dont insert the screwdriver from the bottom you insert it from above the battery tray,or were a battery tray should be if you dont have one on your scooter.Mariner wrote:Thanks very much I'll try both. I think it probably still is the square bolt but has rounded enough for it to spin. I tried getting a screwdriver in from the bottom of the bracket but to no avail. Thanks again
