Page 1 of 2
shortening speedo cable
Posted: Wed Jan 28, 2015 7:28 pm
by dave wheeler
whats the procedure for shortening a speedo cable, does anyone know of anyone who provides this service if its at all complicated?
Re: shortening speedo cable
Posted: Wed Jan 28, 2015 8:21 pm
by TS1-200
I assume you mean the inner, how much did you want to shorten it by
Posted: Wed Jan 28, 2015 9:27 pm
by ktmh5
Surely the OP means the outer cable as the inner has the flats on the end for the drive, you can't cut them off? As for the outer, I usually just get some snips and cut the required amount off, even done it with the inner in situ.
Posted: Wed Jan 28, 2015 9:56 pm
by rosscla
You can shorten the inner and then hammer the flats back in
Posted: Wed Jan 28, 2015 9:57 pm
by Norrie Bodge
theres a tool available to square inner cables
a local guy here years ago did them when we all had extended forks lol
or make one m8 ->
http://www.frets.com/HomeShopTech/Proje ... cable.html
Posted: Wed Jan 28, 2015 10:03 pm
by goldeneye
the best result ive had is cutting the brass ferrule off the top of the inner cable, as when you tighten the outer onto the speedo, it nips the brass ferrule , and causes it to rub, hence the "gieger counter" action of a lammy speedo. shorten the bottom outer cable 15mm, and cut the brass bit off the top, and I find you have a nice sweep on the speedo.
Posted: Wed Jan 28, 2015 10:18 pm
by DigDug
Beedspeed will make one up to whatever length you need.
Posted: Thu Jan 29, 2015 9:38 am
by shocky
Most speedo cables are the same you might find one from a small frame vespa fits my gts has a habit or eating drives and cables its about 20 quid for a new gts one I happend to have a spare lammy one inner only and it fitted a treat cost £1.50 the worm drives worked out at 5 quid from vespa I got the part number and itit was the same as a gillera runner cost £1.70
Posted: Thu Jan 29, 2015 9:48 pm
by gaz_powell
/\ /\ /\ /\ Nice find .......
Posted: Thu Jan 29, 2015 10:31 pm
by TED CRUD
goldeneye wrote:the best result ive had is cutting the brass ferrule off the top of the inner cable, as when you tighten the outer onto the speedo, it nips the brass ferrule , and causes it to rub, hence the "gieger counter" action of a lammy speedo. shorten the bottom outer cable 15mm, and cut the brass bit off the top, and I find you have a nice sweep on the speedo.
Nice one GE
