Page 1 of 4
RT195 or GT186?
Posted: Wed Nov 12, 2014 2:46 pm
by Lamaddict
I've thought about getting GT186 kit but it's easy for me to locally order a RT195 kit. What are they like head to head? I'd be using a 25mm Dellorto and a Clubman style exhaust.
Re: RT195 or GT186?
Posted: Wed Nov 12, 2014 6:40 pm
by Grumpy225
http://scooterotica.org/forum/viewtopic ... 53&t=28793
I've built both and they each have their pros/cons
Personally I'm a fan of the RT for it's ease of setting up, head design and exhaust flange.
Both kits really come alive with the use of a proper expansion chamber and bigger carb as the clubman and small carb are some what restrictive by nature.
how fa$t do you want to go?
Re: RT195 or GT186?
Posted: Wed Nov 12, 2014 7:07 pm
by mickjr
RT for me
Re: RT195 or GT186?
Posted: Wed Nov 12, 2014 7:28 pm
by Lamaddict
I'm happy for a true 75MPH (GPS) but getting there quickly and sitting at a true 65MPH if needed. I do have a 110 Yam rod crank which would suit the GT185 but I'm not sure whether I could use it on the RT.
Re: RT195 or GT186?
Posted: Wed Nov 12, 2014 7:37 pm
by mickjr
ask or email mr bee
Re: RT195 or GT186?
Posted: Wed Nov 12, 2014 11:22 pm
by purple_pill67
Lamaddict wrote:I'm happy for a true 75MPH (GPS) but getting there quickly and sitting at a true 65MPH if needed. I do have a 110 Yam rod crank which would suit the GT185 but I'm not sure whether I could use it on the RT.
Just fit a 3mm packer plate to get round the 110 rod.
Just fitted an RT, albeit the 225 version, and running in at the mo. Pulls and pulls.
Re: RT195 or GT186?
Posted: Thu Nov 13, 2014 1:34 am
by Grumpy225
the RT is well suited for the 110 rod. It's the GT that is designed for the 107/58. Like purple_pill67 says, just run a 3mm packer on the GT to use the 110 rod (you'd need to do that on the RT also).
Re: RT195 or GT186?
Posted: Thu Nov 13, 2014 11:08 am
by Muppet
110 in my gt
Re: RT195 or GT186?
Posted: Thu Nov 13, 2014 12:56 pm
by storkfoot
115 in mine.
I doubt you will find many people who will be able to give you a considered comparison of one against the other given that the RT kits are relatively new. I could wax lyrical about how much I love my GT but that won't help you make a decision.
Re: RT195 or GT186?
Posted: Thu Nov 13, 2014 6:55 pm
by dave wheeler
storkfoot wrote:115 in mine.
so are you using a 8mm packer or a diferent piston?
