Genuine plugs.
- registered user
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
- Contact:
Hi all, after buying what I suspect to be fake NGK plugs (which both failed on me). Could anyone please tell me a reputable place to buy them from? I'm after some CR9 plugs for a Mito Lambretta head. Thanks in advance Pete.
I get mine from my local Unipart outlet ( used to be called Partco ). If they haven't got the type in stock that you want, I'm sure they would order them for you. Of course, any of the reputable scooter dealers should also have them.
- GP Kevo
- registered user
- Main scooter: 1969 150 DL / GP225 TS1
- Contact:
I always get mine at a local motorbike shop or moto parts shop. Never online. They must be genuine, as I've had the plug (B9ES) in there for over a year and haven't had to remove it yet.
They might not knowingly there suppliers might not even know bit unfair to expect themto test every oneTimbo wrote:I can't believe any reputable dealer would sell fakes...
- registered user
- Contact:
Spot on Sir.Donnie wrote:who said he bought them from a dealer???
Ebays renowned for having shitloads of fakes, personally I buy from halfrauds / motor dealers locally now.
I have a Halfords right by me and although expensive they do stock the plugs I'm after. I may just bite the bullet and buy from them knowing they'll at least be genuine..... Cheers Fellas.
- registered user
- Contact:
Important, there's a recommended gap for a reason, an adult will be along in a minute to explain why, and the manufacturers have no idea which engine you'll stick it in so you can bet they don't preset it for you.
If the gap is too small, you won't get a big enough spark to completely ignite the fuel and it will make starting difficult. If it's too big, it will make the ignition coil ( and electronics ) work harder to make the electricity jump the gap. This will lead to premature failure of those components. Stick to what's recommended for your points or electronic set up. Electronic ignition usually has a bigger spark plug gap than a points set up because it's a stronger spark and the system is more efficient.
