Wiring Hoo Ha
Bilko
Main scooter: LI150
I'm having a right nightmare sorting the wiring out on my LI.
Ignition is a honda type, but I've had different configurations given to me and none work.
Really could do with some help sorting this before I crack up.
Bilko's Oily Blog
lockman69
Is it the universal switch (Honda copy, square body, rubber boot) ?
Bilko
Main scooter: LI150
Yes
Bilko's Oily Blog
lockman69
I've just wired one of these into a smallframe, I used the green & black/white on the switch... The lock had to be earthed (or fitted) to the frame....Also I had to remove the rubber boot and cut the loop wire on the back of the lock,mine was red but apparently they can be any colour you'll know which wire once you pull back the boot.
Hope this helps... Good luck
Bilko
Main scooter: LI150
I see the loop wire. Mines black! Just break the loop?
Bilko's Oily Blog
lockman69
Yes mate.... Chop it off.... Mine wouldn't work until I cut it
Bilko
Main scooter: LI150
Chopped!
Still getting nothing. The whole set up is really confusing.
Bilko's Oily Blog
lockman69
Have you earthed the switch?
Bilko
Main scooter: LI150
Yes
Bilko's Oily Blog
Bilko
Main scooter: LI150
There's been so many combinations given, I don't even know what's what anymore!
1 diagram has ignition green as an earth, another to the green on the loom.
Bilko's Oily Blog
