Vespa BGM MRB Clubman - 30.21hp
Post your Vespa dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
MattsDad
Liner is temporary, it'll be getting an aluminium one.
I'll stick it on this engine in a couple of weeks which is more similar to Dan's.
COCKSPEED TUNING
GP240
hey-up T, hope the erectile problem straitens itself out haha.
cant believe your trying to make the tourer go faster, nearly ripped me arms out of me shoulder lol.
oh an av another glass of red an put up some more graphs of the A/F you worked on.
fairspares
GP240 wrote: oh an av another glass of red an put up some more graphs of the A/F you worked on.
id like to see that to as it looks identical to the one Ben@AF and myself built.
GP240
Sorry Shaun, I thought your engine was the one Tony worked on, my mistake oops.
MattsDad
Sorry I didn't mean to cause any confusion.
You lose track don't you, because on that photograph of a graph some text is deleted by black marker pen so I'm not sure.
I don't think its the same engine though because on this thread its stated the initial sequence of events and tune to work with was:
"Race Rapido fast road , 72mm bore, 58 stroke ,franspeed race pipe ,37mm koso, 10.8/1 comp head, 1.2mm squish, timings: standard transferes 130 with casings matched 240 inlet , 189 exhaust, fitted with reed block and single boost port , green line with bgm rd reeds 23.2 bhp , blue line straight swap for v force rd 350 block 26.3 bhp , red line slight fiddle with jetting 28 bhp , il put up the torque figures when i can find the graph".
http://scooterotica.org/forum/viewtopic ... 45&t=23872
The one I worked on was completely different and I know because I was there doing it and still have all my notes, so it mustn't be the same:
1. 08/09/2012 - green line - 126/187 durations, 0.10 base, 1.60 head, 1.55 squish, 23.23 hp
2. 28/09/2012 - blue line - 130 / 188/9 durations, 1.10 base, no head gasket, 1.10 squish, 26.31 hp
3. 13/10/2012 - red line - All same as number 2 with addition of Vforce 3 Tassinari, no jetting changes whatsoever - 28.06 hp
COCKSPEED TUNING
MattsDad wrote:Liner is temporary, it'll be getting an aluminium one.
Great result that, I love the curve. Whose Dyno is it?
Darrell Taylor
Main scooter: LAMBRETTA
how did the mjp compare to the dynojet on shauns sprinter dan?
Darrell Taylor wrote:how did the mjp compare to the dynojet on shauns sprinter dan?
You'll have to ask Shaun, as posted in the relevant thread.....i can't comment without Shaun's permission.
Darrell Taylor
ta ,will see him at weekend
Darrell Taylor
MattsDad wrote:Sorry I don't really use or own standard pipes but hopefully will be doing an expansion comparison next week.
Its new engine build and not standard. Not welded, 57 stroke, Vespatronic, reed, centred head, and TM carb.
Its got packing options to make into a touring tune also so will graph that too.
Here's the torque which shows efficient bmep peaks so happy will that and more than surprised the pipe revs through this far:
just noticed on this graph of the lambretta dyno put on by accident that the correction factor is missing/cropped off the picture ,i took a look at the old rapido 42bhp post and found the correction factor shown is sae 1.21 whereas the vespa graphs are 0.96 / 97 which is more or less what uk weather corrects to fluctuating from min 0.95 to 1.05max
this means the power figure shown is inflated by 0.25 which corrects to a real figure of 31.34bhp be worth asking the dyno guy for a new graph with the the appropriate correction applied
if the original 26.31 graph was 0.97 and the 1.21 applied you,d see 32.8
figures arent perfectly calculated ive applied 25% for the 0.25 which is close
id presume the old graph at 26.31 was around a 0.97 correction
and new graph with new tune 31.34 with 0.97 correction applied so a healthy 4bhp increase all the same
