Rear Hub NUT GP on SIL engine
vespinello
Hello,
Do you know if the rear hub nut does exist in different dimension?
Here below my problem
Original Nut from my original LIS engine
Original nut + fixing kit for SIL hub
I can't fix the hub....i have too many space between the hub and the nut
What esle :cry: ?
From Jupiler Skouter Club
is the cone shim on?
vespinello
Cone shim = part nr 20 ?
Yes it 's on...but i'm not sure that's the orginal one...the shim that i use is 1mm thick...
Soulpunk
don´t use grease there.
for the nut, there are nuts with a deeper head. also had that problem on some scooters.
essential also is the cone. there are 3 different types of angles. the angle in the rear hub and the cone you use must be the same. its absolutely essential.
simon
Barry Turner at scooter warehouse sells the longer threaded nut, if that’s what you need :? :mrgreen:
vespinello
Ok thanks for your help..i 'll try with a longer nut
eibargum
I,d try it with a normal nut [not domed] first and if all,s well get a deeper one, simples :D.
RBG
vespinello wrote:Image
No 20.
    Users browsing this forum: Ahrefs [Bot] and 5 guests
