Starting Problems
- GTFOMWSC
- registered user
- Main scooter: GP230 Super Monza CS Tuned
- Contact:
Fargo Scooters in Cov but they're very busy at the moment so i'm told can also recomend Keith at Red Dog Lambretta in Leamington SpaBlenks wrote: ↑Sun Jul 22, 2018 8:08 pm First chance to run it was today. Started first kick did about 6 miles to a mates. Started hot no problem. Did a run of about 20 mile, stopped for a drink. Strarted 3rd kick. Did another 10 miles home left it for about 45 minutes and would not start. Removed side panel carb side and it started. Tried it again and nothing. Removed the plug and it look good. Refitted tried again to start, nothing again. Pushed it back in the shed and broke down in tears when it won’t start it is like there is no spark at all. I am thinking now that it may be the ignition switch but only because I don’t know what else to consider now. Anybody recommend a good repair shop in the West Midlands as close to Coventry as possible.
the man don't give a f@@k
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
Yes, Magpie Scooters. They are in Coventry and do good work.
- registered user
- Main scooter: Lambretta S3 Li150
- Contact:
Its been in to Fargo's twice without success. They fitted the ignition switch and cleaned the carb and also fitted a new filter. I don't know Red Dog in Leamington but will look them up. Thanks for the suggestions.
I was advised through this forum some time ago that restoring a scooter can become a money pit. They were absolutely spot on!!!
Disconnect the green switch wire from the CDi and ride it like that. This will prove or disprove it's the switch at fault.
When it refuses to start, remove the sparkplug and check for a spark. If one is present it probably isn't an electrical issue.
- Doom Patrol
- registered user
- Contact:
I should add their number is...Doom Patrol wrote: ↑Mon Jul 23, 2018 2:00 am Yes, Magpie Scooters. They are in Coventry and do good work.
024 7642 1000
http://magpiemotorcyclesandscooters.com/
- registered user
- Contact:
Just been reading a couple of guides on spark plugs on the net. One speaks about the difference between resistor and non-resistor type plugs and caps. It states that resistor type plugs, leads and caps are best avoided and can cause starting issues. I know I have a resistor type NGK cap and a NGK B7ES plug (don't know which this is) and not sure on the lead either. Any thoughts on whether this could be a contributor to my starting problems? I had not heard this before today. Plug, lead and cap were all new when the scooter was rebuilt.
- registered user
- Main scooter: Lambretta 1964 225 Special
- Contact:
That is not your problem.
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 11 guests
