I thought your hems would make you more 'sensitive' to small jetting changes? LolYanker wrote:Yeah but Dan, the 'seat of the pants' 'method' just gets harder if you suffer from them as i do. SHey-Ho, suppose I'll just have to dial-in my PWK 33mm the old way then..........
Carb setting for Malossi210 MHR
- drunkmunkey6969
- Moderator
- Contact:
Depends which way the wind blows TBH, but your/my hems could be a deffinite drag factor impediment, unless.......some Bittish (Or Enghlish speaking) scooterists properly get to grips with these wonderful Kehin carbs wot they iz.
- drunkmunkey6969
- Moderator
- Contact:
Had mine banded.....not like a clutch, that's different.
- registered user
- Main scooter: Lambro, GP.
- Contact:
^ or if I've got a partially wrong interpretation.
Butt Plugs! (I'm off to sulk and insert you twats)
- registered user
- Contact:
