TS1 Jetting on Delorto VHSH 30 mm Carburettor
- Main scooter: Lambretta LI Special 225
Hi Folks, just wondering if anyone has a TS1 and using an Avanti Ex-Box if they could kindly advise their carburettor set up in terms of jetting. Many Thanks
try..
MJ:155
DQ262
Needle:K5
Pilot: 60
Float: 300
Choke: 60
Emulsifier: B48
Slide: 50
MJ:155
DQ262
Needle:K5
Pilot: 60
Float: 300
Choke: 60
Emulsifier: B48
Slide: 50
correction: emulsifier CD1
- Main scooter: Lambretta SX200
I thought DQ for piston ported & DP for reed valve engines
I need to check what I say, but will be rebuilding a VHSB this afternoon to go back on a TS.
