Hi
Can I use a standard exhaust on a Indian G.P. 200 engine or do I have to use a big bore. I'm sure I read somewhere that the exhaust outlet is to big for a standard exhaust . Just want to make sure before I buy a new pipe.
Standard exhaust
- registered user
- Main scooter: Lambretta L.I. 200 special
- Contact:
The standard size exhaust will probably make your standard engine run smoother better and quick. I think, I’m some cases we’ve been told bigger is better but it’s not always.
- registered user
- Contact:
I thought the Indian barrel was designed for the big bore.
40mm SIL Clubman I believe.
- registered user
- Contact:
So could I put a standard pipe on. The clubman pipes are too noisy for me.
As long as its suitable for a 200
- registered user
- Contact:
Great .thanks. No more waking the neighbours when I go too work at 5am
- registered user
- Contact:
Find an exhaust gasket that matches the exhaust port(or even use a piece of paper to take a pattern) then put it onto the exhaust flange to see if it is the same. If it's not, get the file out and make it the same. You'll know you have no obstruction then.
That's not going anywhere...
- registered user
- Contact:
Cheers. Will give that a go. Going order standard pipe from scootopia
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 12 guests
