Mikuni TMX 27mm or 30mm
Train Driver
I have a TS1 with left hand LTH manifold, my carb at the moment is a phbh but it's all a little tight.
Do any of you have experience with the 27 or 30 TMX.
B-Race Tuning
Main scooter: Lambro, GP.
Not sure you'll get it in the post, fitted and dyno'd in time my friend. You've only got 4 days ;-) £'s per, is it worth it? Really. And they are also a little tight. S
Train Driver
:shock: :lol: :cry:
27 & 30 are the same dimension, surprisingly the TMX35 is quite a bit thinner so better panel clearance.
Successfully used the TMX27 for several years but on a new build I'd use a TMX30 as you need to fit the needle from the 30 to the 27 and the choke convertion is about £15 more on the 27, therefore the 30 works out about £25 cheaper.
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 13 guests
