been out and about,running in scoot(225 kit),it is leaking oil all over the back wheel,have checked the sump plug,ok,oil seemed to be coming from one off the chain case bolts,tight end that up(it did tighten up slightly),any other ideas?
duc748
oil leak
'O' ring on the selector shaft.
how do i find if breather blocked?
- registered user
- Main scooter: honda
- Contact:
Give it a rinse, dry off and see if you can blow through it.
Double check for over filling first. Carefully clean all the leaked oil off. Remove breather. Shove a bit of tissue lightly in the hole to stop any splashing. Go for a run round the block.
