[/quote]
This is what I'm looking for, but about 4k revs earlier
anyone ???
VESPA DYNO GRAPH POSTING AREA
Heres Mongos T5 which I must admit turned out better than I expected it to.
Engine is:
Polini barrel bored to 64mm and some exhaust port work. Suzuki TS185 piston
T5 crank gasflowed using a DRT eccentric pin to give 54mm stroke built by Pro Porting
Taffy Pipe
M-Tech retarder
Std carb with 135mj flowed inlet
Pulls 22/68 very easily
19hp 16ft/Ib torque
Engine is:
Taffy Pipe
M-Tech retarder
19hp 16ft/Ib torque
AlDiablo wrote:Heres Mongos T5 which I must admit turned out better than I expected it to.
Engine is:
Taffy Pipe
M-Tech retarder
19hp 16ft/Ib torque
that dip from 4000 to 5500 what causes that
Train Driver, why are you looking for this, its a scoot that has seized?
anyone ???[/quote]
This is what I'm looking for, but about 4k revs earlierTrain Driver wrote:
anyone ???[/quote]
COCKSPEED TUNING
- Main scooter: vespa t5
Heres mine 172 t5 with malossi reed valve and 128 carb with a scorpian got a taffy on it now and going to put a 21 tooth cog on clutch plus chris said he will open exhaust port on it a bit so will post another up after work done to see if any difference
anyone ???[/quote]
then ride your lambretta as thats what you have. vespas are for shopping.....my polini is like riding a ride on mower.
- H,POOL GADGE
- Main scooter: vespa polini220/gts 300
http://farm8.staticflickr.com/7368/9373 ... e947_b.jpg
dyno reading - vespa px200e - polini alloy 210-pinasco reprofiled head 10:1-pinasco 60mm crank-24/24si carb 48/100 idle-140 air corrector-be3-125 main-standard 4th gear- carb inlet timing opened-crank inlet timing opened-exhaust port widened a touch -JL r/hander -
pulls like a galloping horse, uphill and head on wind, with a dollup of high rev fun factor, over the moon with setup, 19 BHP + 17 TORQUE!!!
tune, work and dyno cutiously done by the legends DAN & SEAN @ Scootererotica!!!
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Lol....cheers Gadge.
Note...you have highlighted the curve incorrectly, you've started with BHP in black and then at the point where they crossover you've followed the torque curve. I'll see if I can re-post a correct image
- Main scooter: GS150 x2, Primmy, PX & GTS
