malossi 210 longstroke
1469leach
Main scooter: jet200/rapido 225
Long stroking it will help with the torq side of it and will aliviate some of the up and down the gear syndrome.Never done the mods that Norrie is suggesting but sounds like that will help too.Norrie 2mm squish,why so much?
Cheers Jeff
hobospeed
I'm going to be changing my rotary 210 to a 60mm crank soon. I'm toying with the idea of doing the "Kabawelle" or "Flexkiller" web mods as the Germans seem to be getting good power boosts from them.
Very extreme version on a 62mm crank:
lol,i,ve been cutting vast amounts of metal away on reed valve cranks for years
Norrie Bodge
1469leach wrote:Long stroking it will help with the torq side of it and will aliviate some of the up and down the gear syndrome.Never done the mods that Norrie is suggesting but sounds like that will help too.Norrie 2mm squish,why so much?
Cheers Jeff
typo m8
1.2mm squish
1469leach
Cheers thought I was missing something then.
All the best Jeff
MCH
Main scooter: street racer px
Anyone run a 62mm crank instead of the 60mm?
just thinking about maybe going for the 62mm, more torque,
i know I will to work out my port timings, but fancy doing the 62 over the 60,
would I need to take the skirt off the bottom of the piston?
Train Driver
MCH wrote:Anyone run a 62mm crank instead of the 60mm?
Alan Terry (Diablo) was going to make me a 62mm but I changed my mind, contact him or Harry
Have a butchers here, not cheap but very good quality.
http://www.kingwellen-shop.de/index.php ... frame.html
MCH
iv spoken to a lad i know who has a 62mm crank set up , but he said he goes through piston rings more since changing to 62 from 60
any thoughts on that?
MCH
also im thinking when i longstroke my motor,
i might go back to using the si 24 carb, possibly with polini venturi, but run the hose instead of filter,
can increase float chamber with spacers and use the cosa chamber, with the larger needle hole for fuel flow,
anyone got any advice on running it with the si carb, just thinking about clawing back some of the fuel consumption
    Users browsing this forum: Amazon [Bot] and 9 guests
