Output is 90° away from the pump and the straight inlett is the input. The liter/min from my recomended pumps is very high, maybe 20-30 Leiters per min. I don't know the electric consumption - I supply the pump at my racing Scooter with a battery and the battery with my Vespatronic but the battery is alwasy charged at home. So if the output from the Vespatronic is lonely enough to support the powerfull Pumpe, I'm sorry-I don't know that.tonydevon wrote:I been looking at the BGM or motoforce unit, BGM is winning at the moment as its sealed from the elements
do you happen to know off hand what the direction of pumping/flow is?
due to where I want to locate the pump I need it to go a particular way.
thanks
Cheers
Michael
