Mallossi 210 Tune - 23.5bhp & 18.5ft-lbs - Touring Tune
Post your Vespa dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
Mallossi 210 kit - Scooterotica porting spec to Cylinder & Casings (Touring Tune)
28mm Delly
JL3 RH Pipe
Reed Valve Conversion
Scooterotica Gas Flowed/Cut crank
Steady power starting from just over 4200rpm through to 8000rpm.
Peaks at 23.5bhp - with rich jetting (AV266 & 138 main) on a little 28mm carb. Over 25bhp should be easily achievable with a 30mm Delly and 135 main, but leaves less room for temp changes, so happy with this nice touring set up. Good power at low to mid revs.
Nyle
What type of port timings are you running on your transfers and exhaust ;)
Nyle wrote:What type of port timings are you running on your transfers and exhaust ;)
What type? really nice touring ones..... :lol: ;)
Spanish Fly
Main scooter: P200e
Dan.
Do your "Touring Tune" porting mods give more bottom end power than a standard Mallossi?
Cheers.
SF
Yes. Ill find some 'common' 210 graphs and see if i can get them uploaded to compare.
210s are very peaky and lacking in mid range in my opinion, we tackle that problem with this tune.
Spanish Fly
Main scooter: P200e
drunkmunkey6969 wrote:Yes. Ill find some 'common' 210 graphs and see if i can get them uploaded to compare.
Yeah good. Should make an interesting comparison. ;)
SF
SF
can you also provide some of your results also ...interesting to compare and discuss
