Dellorto 25 on J125 TZR conversion. Help needed.
Supereibar
grimspeed wrote:Stud spacings are the same as a 150 large frame !
Inlet and exhaust !
What frame are you using ?
The cylinder studs have the same space as Li kind?!?!?
e type
what sort of timing is people running on these?
joey
...here's my manifold....
...fit a lunatronic...or get busy converting a vespa/af system.....
Supereibar
hmmmm very very nice... BTW don't you find those spark plug caps to come off? I have discovered the silicone ones and I don't want to use anything else now! :D :D :D
joey
...thanks... use those caps on all scoots as they are water proof for the english summer and have had no problems...but i'm thinking of changing it to a black one with a red lead....so there! :o ;)
also lunatronic coil/rectifier now installed neatly under rear mudguard...
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 9 guests
