VESPA DYNO GRAPH POSTING AREA
Post your Vespa dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
Train Driver
Image[/quote]
This is what I'm looking for, but about 4k revs earlier
anyone ???
Diablo
Heres Mongos T5 which I must admit turned out better than I expected it to.
Engine is:
Polini barrel bored to 64mm and some exhaust port work. Suzuki TS185 piston
T5 crank gasflowed using a DRT eccentric pin to give 54mm stroke built by Pro Porting
Taffy Pipe
M-Tech retarder
Std carb with 135mj flowed inlet
Pulls 22/68 very easily
19hp 16ft/Ib torque
Train Driver
Diablo wrote:Heres Mongos T5 which I must admit turned out better than I expected it to.
Engine is:
Taffy Pipe
M-Tech retarder
19hp 16ft/Ib torque
Al
that dip from 4000 to 5500 what causes that
MattsDad
Train Driver, why are you looking for this, its a scoot that has seized?
Train Driver wrote:Image
anyone ???[/quote]
COCKSPEED TUNING
gimp1971
Main scooter: vespa t5
Heres mine 172 t5 with malossi reed valve and 128 carb with a scorpian got a taffy on it now and going to put a 21 tooth cog on clutch plus chris said he will open exhaust port on it a bit so will post another up after work done to see if any difference
cezeta
anyone ???[/quote]
then ride your lambretta as thats what you have. vespas are for shopping.....my polini is like riding a ride on mower.
H,POOL GADGE
Main scooter: vespa polini220/gts 300
http://farm8.staticflickr.com/7368/9373 ... e947_b.jpg
dyno reading - vespa px200e - polini alloy 210-pinasco reprofiled head 10:1-pinasco 60mm crank-24/24si carb 48/100 idle-140 air corrector-be3-125 main-standard 4th gear- carb inlet timing opened-crank inlet timing opened-exhaust port widened a touch -JL r/hander -
pulls like a galloping horse, uphill and head on wind, with a dollup of high rev fun factor, over the moon with setup, 19 BHP + 17 TORQUE!!!
tune, work and dyno cutiously done by the legends DAN & SEAN @ Scootererotica!!!
Lol....cheers Gadge.
Note...you have highlighted the curve incorrectly, you've started with BHP in black and then at the point where they crossover you've followed the torque curve. I'll see if I can re-post a correct image ;)
culturesponge
Main scooter: GS150 x2, Primmy, PX & GTS
here's my Worb5 Malossi 210 motor dyno from Jan 2007
alex
    Users browsing this forum: Amazon [Bot] and 5 guests
