-I see that opening up the lower part of the cvf in the piston will improve gasflow, should I open the upper, small hole aswell?
-Timings are now 171/124, that gives 23,5 blowdown, is this gonna work with the sip road?
-Xport is 58% wide, should I widen it or will this be good for a allround tourer?
Rest of motor looks like this
bgm 60mm crank
si24 ovalised
sip road
rotary, 120/65 totalinlet 185deg
old clutch and std gearbox
looking for a reliable tourer that will sit at 60 all day with reasonable fuel consumtion
heres a couple of crappy cell pics
