I want to put this hydraulic caliper to my original inboard disk brake but is the first time that i bleed something like this.
I have this caliper from Foxy (from LCGB forum):
The black allen screw have a small ball inside.
Thanks!
OK, thanks Shocky, i know this bleed nipples but i like this hydraulic caliper because can use it with original disk brake I-cap and i think that if i put this bleed nipple there is no space to put the I-capshocky wrote:i wouldnt bother, i have some experiance at working for a small m/c dealership allbe it a fair few yrs ago and we fitted these to anything that was hard to bleed
you need to check what thread pitch you have though
Seems difficult for meshocky wrote:true you will have to fit it and lie the hub on the floor or flat surface with the bled nipple upermost or stood up with it at the top or slightly lent over and try and bleed it that way id use dot 5 fluid so it doesnt wreck the paint
