Lambo crank reedvalve
Steviemonster
saw this on a New Zealand website....
its not a crankcase reed set up steve............. :D
Steviemonster
aww! after all that! took me ages to track it down!!
Knowledge
Martin
whats the red thing straped to the left hand mount?
looks like a starting motor :shock:
carlos fandango
looks more like a filler cap for the water cooling :D
carlos fandango wrote:looks more like a filler cap for the water cooling :D
may be a water pump driven of the fly wheel?
Knowledge
Thanks for the spectulation, but I'd rather you hadn't spotted it.
Yes, it is an electric starter. The flywheel was an original AF lightweight item, with the starter wheel from a Piaggio Sfera machined into the face. Nice.
When I finally bolted it all together and pressed the starter button, it turned it over (just), but in the wrong direction. :o
This rates at about 11.7 on the oh-sh!t-o-meter.
I'm over it now........ :(
Martin
