half circlip for delly 30
DaveTomo
Main scooter: SX 200
Anyone know where I can get a delly 30 circlip that give a half position on the needle,for example X7 clip position two and half.So that it holds the needle in between the grooves on the needle.A link would be very much appreciated,thank you.
Dave do http://www.dellorto.co.uk/ not stock them ?
DaveTomo
Cheers Toddy,had a look on there but not sure which is the one I'm after ,whether its this one http://www.dellorto.co.uk/merchandise/p ... ctionID=24 or this (which I think is the standard one) http://www.dellorto.co.uk/merchandise/p ... ctionID=24 so I was hoping an adult could show me which one :oops: :oops:
nelson pk
DaveTomo wrote:Cheers Toddy,had a look on there but not sure which is the one I'm after ,whether its this one http://www.dellorto.co.uk/merchandise/p ... ctionID=24 or this (which I think is the standard one) http://www.dellorto.co.uk/merchandise/p ... ctionID=24 so I was hoping an adult could show me which one :oops: :oops:
Its neither!
The half clip effect is done by using a small washer under the c clip (I think you'll find that it's not a standard delly part). Cambridge lambretta sell them. Look in the carb jets/needles section. ;)
Eibar
Main scooter: Eibar TS1 1966
just take your slide and needle to a supplier of fasteners and get a bag of extremely small washers, make sure they fit over your needle and in the recess on the slide, they cost a few pence so buy loads
potato
DaveTomo
Thank you chaps,much appreciated found it http://lambretta.co.uk/catalog/product_ ... ts_id=2866 and thank you for putting me on the right track
