Minority, where did you get those from? Everywhere I look they only seem to come in 18mm lengths and having just checked the spacers on my scoot, they'd need to be 25mm or 26mm long.Minority wrote:You mean something like this?belly wrote:Get some long nuts made up same length as spacer then you can keep the studs in chaincase, attach bracket with bolts on other end, saves using screws in and out of alloy![]()
Removing studs out of engine case
dapper
- registered user
- Main scooter: The Biriani Bullet
- Contact:
But not liking the full back Ancilotti type rack fitted with a shorty Ancilotticorrado wrote:I do like the stance of that exhaust, satin Black or Carbon endcan would look great on the scoot. I posted some pics a few months ago of an all Black one.
Just my opinion, nice exhaust though.
Minority
- registered user
- Main scooter: Li230 S3
- Contact:
Got a couple of sets from two different sources and they were both 25mm. However that's in Perth, Western Australia so not much use for you.dapper wrote:Minority, where did you get those from? Everywhere I look they only seem to come in 18mm lengths and having just checked the spacers on my scoot, they'd need to be 25mm or 26mm long.Minority wrote:You mean something like this?belly wrote:Get some long nuts made up same length as spacer then you can keep the studs in chaincase, attach bracket with bolts on other end, saves using screws in and out of alloy![]()
However it does suggest that it's a common size, so you should be able to source it easily in the UK
- corrado
- Dealer
- Main scooter: Lambretta GP
- Contact:
The 6mm to 8mm studs that MB sell may be worth considering for this job as you can then you extended 8mm nuts and 8mm bolts, may beef the whole thing up.
http://www.lambrettaspares.com/spares/s ... p0302.html
8mm x 25mm long nuts.
http://www.ebay.co.uk/itm/M8-8mm-BZP-TH ... 5d48fc9fc2
How much !!!!!corrado wrote:The 6mm to 8mm studs that MB sell may be worth considering for this job as you can then you extended 8mm nuts and 8mm bolts, may beef the whole thing up.
http://beedspeed.com/fastener-repair-st ... -6820.html
- corrado
- Dealer
- Contact:
Agreed.shocky wrote:How much !!!!!corrado wrote:The 6mm to 8mm studs that MB sell may be worth considering for this job as you can then you extended 8mm nuts and 8mm bolts, may beef the whole thing up.
http://www.ebay.co.uk/itm/M8-8mm-BZP-TH ... 5d48fc9fc2![]()
