Hi can anyone give me a heads up on a timing gun, and if I were to buy one with a tacho is it worth the extra money and will it work on two stoke ok ?
Its my birthday soon so can spend a bit of money
P.
Recomend me a timing light/gun please ?
- Main scooter: The Biriani Bullet
I use this one as do many others. You may find it cheaper but this is the first one that popped up on e bay. You need a battery to use it. Simple but effective and accurate.
http://www.ebay.co.uk/itm/Draper-52616- ... 2c51550057
- Main scooter: 1960 S2 Italian
Great seems very reasonable , this might be a simple solution.dapper wrote:I use this one as do many others. You may find it cheaper but this is the first one that popped up on e bay. You need a battery to use it. Simple but effective and accurate.
Do you have any more info. or details regarding this, just hate buying things twice, done that enough with scooter parts!Muppet wrote:try t get one with skip technology so it work to higher revs
High-tech internal circuitry-auto-ranging allows the timing light to skip every other flash for a brighter light and longer lifeRotor wrote:Do you have any more info. or details regarding this, just hate buying things twice, done that enough with scooter parts!Muppet wrote:try t get one with skip technology so it work to higher revs
Cut n pasted from tinternet
C’est la vie
- Main scooter: Lambretta GP Monza 225
+1dapper wrote:I use this one as do many others. You may find it cheaper but this is the first one that popped up on e bay. You need a battery to use it. Simple but effective and accurate.
- Main scooter: Lambretta li150 special
They work OK, used mine again this morning.
